A bit of a newbie here, please excuse what may be a obvious solution to some 😉
I am installing the Behringer Mix-Sequencer Module 1050 into the Arturia Brute 6U. There are two cables, one of which has a 10 pin connector. Do I need to purchase a adapter, or is there another solution? Thank you in advance for any assistance.
Two cables? Use the 10-to-16 pin cable. 10 pin connection to back of module, 16 pin connection to upper or lower power in 6U Rackbrute. You shouldn't have to worry about the red stripe (-12v). Both Behringer and the Rackbrutes use keyed headers so things will align naturally.
edit: I haven't seen the back of that Mix Seq so I'm assuming there is only one 10 pin connection.
