Hi all!
This is my first time setting up a modular synthesizer and I would like to ask you for help and advice to see if I am on the right track. The type of music I'm going to make is cinematic music. For that, I'm planning to use the nerdseq to sequence the pizza and the ensemble oscillator as well as some squid salmple samples and then the marbles clone to sequence the remaining squid salmple samples (mostly percussion sounds). The effects are the mimeophon and some guitar pedals that I'm going to use via ALM SBG and that I'm going to pass as sends in the Mix BX.
The rack:
https://cdn.modulargrid.net/img/racks/modulargrid_1999858.jpg
My main questions are:
-Do I have enough VCA and modulation sources?
-Do I need more utilities?
-Would you change anything to improve the workflow?
-Does it make sense at all?
Thank you very much in advance!
