Hi all. I'm having problems with my cara getting synced right in time when I sync it to an external clock.Well it syncs but with a latency that lets it play a little bit too late. Any ideas about that? Are you have the same issue?
MINI MARBLES
http://antumbra.eu/redesign/cara
Maybe double check the Jitter setting?
Jitter is fully counterclockwise
External clock edges nice and square?
what are you using for the clock?
are you talking about t2, or t1 &t3? if t2 it sounds like maybe a dodgy module, if t1 and/or t3, then maybe the gate output setting have been changed - see manual ...
I'm using the clock output from the Eloquencer. I'm refering to t1 t2 and t3 in every states. I will check the output settings
