Looking for a simple headphone output for my eurorack which I can also use as an audio output to my audio interface (Steinberg UR22C)
I've narrowed it down to the ALM HPO and the Joranalogue Transmit 2
Second hand I can get the HPO for £70 ($82) less than the Transmit 2
Would welcome advice on which one to get
I'm starting out and will principally be using it for headphones
Thanks!
Well, whip on this, then: https://www.modulargrid.net/e/happy-nerding-isolator-2022-silver
With this new 4 hp-er from HN, you not only get a PROPER 1/4" TRS headphone jack and preamp, you also have balanced TRS outs for left and right. And the cherry on the cake here, you CAN'T see...because it's the transformers inside the module, which not only isolate your modular from the interface to control noise and ground loop issues, but you can "punch" them a bit harder and, like any good audio transformer, you wind up with that "big iron" warmth due to a touch (or more!) of saturation.
Some don't dig having an output module of this sort. But having seen ground loop and signal crud issues in both dive bars and high-end Nashville studios, I think it's a pretty useful addition, as you never know when you're going to come up against those sorts of issues.
Arrandan
Hi Lugia,
Not doubting your experience with the HN module, but the Joranalogue claims to have all of that in some form or shape as well. The headphone jack is 3,5mm instead of 6,3. But you get XLRs which are very common in pro environments and easily converted to 6,3 jack with a cable. The module claims to overcome the problems of galvanic isolation by using solid state components. I don't know enough about it to evaluate if that's going to be true or not. I'd like to hear what you think of it. I was considering this module as well.
Ive got a hpo for sale if you Are located in the EU
Thanks!
-- MrMojoRisin
The HPO is the no-nonsense solution in a small rack and does a decent job for me.
More often I am using the Erica Pico OUT since I usually do monitoring on a set of 3.5 mm jack earphones and record on a pocket recorder at the same time. It's my go to for that scenario so I have one in all of my small cases.
