Hi,
all I wanted to do, was look for a way to control my DFAM from my desk or preferably DAW and I ended up falling into some kind of eurorack trance, where I took the last 3 days to try to 'solve' assembling a proper case. I'm kinda healed for now. This is what I came up with (below), after assigning a more fixed purpose to the build (at first I thought "great I can get a BBD & spring reverb!" but i had to quickly realize to prepare all those things for stereo processing is not worth the effort, sadly).
Some notes on purpose: What I usually do when producing is creating loops and mangling them with heavy modulation in bitwig, multifx (triad, hy-filter 4 that kind of thing), stacked comps, chained reverbs etc. I then print those loops and slice them again using the new slices in creating the actual track. Now, I'm trying to do this same process assisted with my eurorack case and also have better integration of my DFAM (which i avoid using atm, as its too much trouble). That's the goal with the case.
Some notes on the module selection: The top row has lots of stereo units, because I want to use it as a stereo processing chain from an external signal. That's why there are also 2 Antidotes. In my imagination, I can use those Antidotes as a dual channel signal processor. Love the sound of it, love bbd and the broken strings that come out but not sure it will be useful in the way I imagine. The single OSC + Noise is there for layering. I can also use the Multimode Filter + Noise to create a snare or hihat sound to use with the DFAM. The smooth oscs of the DFAM should also go well with the Antidote as contrast. There's only 3 VCAs now and thats maybe not enough. I honestly forgot that the Noise is a voice as well. The Antidotes don't take VCAs for loundness as far as I understand, i didnt count the DFAM and then it was basically 1 voice (+noise). Data Bender, Inertia, Ataxia are there to bring variation to the loops (with Pam). But honestly, I don't really understand what Inertia does practically (how I would use it) but it sounds like something I want to use.
Trade-offs: I decided in Pam over FH-2 because I wanted a dynamic clock source to start thats more hands on, even tho I have a launchpad so FH-2 would be great for midi sequencing. I would also like to have an EQ in there at some point, a better way to interface with my daw (ES-8 e.g.) and an envelope sequencer (Maestro). I decided to skip on disting/ex for now, as I want to integreate the setup tighter with my DAW and see what digital functions I would really want after (and no need for e.g. sample based voice or a dsp granulator etc.).
Questions: (a) I'm not sure Data Bender is a good idea. I really like Data Benders concept but its basically alot of what I do ITB and maybe I shouldnt just try to recreate my ITB workflow (because this rack should add something different). Maybe someone has an opinion on this? (b) I'm not really sure how I would use rise/fall practically (offsets and signal delays to a lesser extend). Also the whole VCA thing still throws me off, I understand conceptually, why i need them but I never think about VCAs ITB and I don't yet understand why I wouldnt just get a FH-2 + expander and just do everything over those units. (b.2) With that im not fully sure what Inertia/Demix will do but I hope, I'll learn after getting a couple modules to start out.
Right now I only have the DFAM (and a Model D), so my plan is to actually get the Mantis case (this one already became cramped at the end and I would like to have the DFAM inside the rack for practicality reasons) and maybe 4 modules + i/o. I would probably start with something like DFAM + Eumonia, Ataxia, Antidote + Pam and some I/O. Im not decided yet on the midi & i/o part.
TL/DR: Man seeks to mangle audio from DAW and create quirky loops with DFAM. Did he do this right?
If you made it through the long write up (or not :>), what do you think? Is there anything conceptually or practically broken with this case layout in regards of what I want to do?
-- rckitup
Yes...and no. And the "no" part has to do with having the DFAM in your cab, filling up 60 rather spendy HP. You should take that out, put it back in ITS case and on ITS power, and leave the cab for things that have neither. As for the "yes"...it's sort of conditional on that DFAM's presence as well. Thus far, the module choices are OK, but there's quite a bit missing which also requires putting the DFAM back where it belongs. There's things that could be done better here, but if you don't have room for the modules that would need, you're sort of stuck.
-- rckitup
Okay but what would I be missing? I guess you mean the 3 Envelopes the Dfam can put out? Im interested.
i did rework the whole case tho, ill probably post a more focused question soon, theres a couple of things im getting stuck on.
-- rckitup
Sure...in fact, you could probably reconstruct the DFAM as modules. It'd be way more expensive, but it'd also probably fit into the space the DFAM takes up now...with some left over.
For instance, the DFAM's EGs...it would make far more sense to get FOUR...and proper ADSR EGs at that. So, check THIS out: https://www.modulargrid.net/e/xaoc-devices-zadar. This can do FOUR...with assignable CVs per EG, plus it can be had with a 3 hp expander that lets you directly address the EGs' behavior. That gives you your three...plus one more, plus a number of different envelope types, plus CV control. In 13 hp.
And so on...
