Hello,
i have a question about using a quad quantizer. I understand that you can set a scale for four different inputs. Let's assume that I have four different sequences and I use the quantizer to transpose them to the same scale. But that doesn't automatically mean that all the tones fit together when the four sequences are running. Maybe I don't quite understand the exact scope.
How do you use a quad quantizer in your setup?
User left
Indeed, being in the same scale doesn't necessarily mean consonant. You can still get dissonant intervals playing at the same time, eg. a 2nd or a diminished 5th.
If inputting random uncontrollable CVs, like from an LFO or S&H, I'd recommend to set the quantizer to a specific chord, rather than a scale. This minimizes the risk of getting unwanted dissonances, if any.
I guess full scales are useful when you're inputting a more controllable source, like an unquantized sequencer, where you can set each step to specific positions until you get a combination of notes you like, and they stay there.
I hope it makes sense.
a quantizer doesn't necessarily transpose - some can but most won't, you would normally use a precision adder for transposition, what a quantizer does is drag the input voltage to the voltage of the nearest note in the specified scale (which may be up or down depending on how the quantizer has been programmed...
with a quad quantizer all 4 inputs are usually quantized to the same scale
if all 4 of the outputs are voltages in the same scale, then they will be harmonious - this doesn't necessarily mean that they will sound how you want them to... the oscillators or voices need to be tuned - probably to the same root note, but not necessarily in the same octave - and they have to be able to track in the range that you are sending notes to them - ie probably not over 10 octaves - and the sequences have to be programmed etc
how do I use a quad quantizer in my setup? I have a sinfonion, I send it 3 or 4 sequences (made up from marbles, erica black sequencer, tesseract step fader etc), note mask each part as required and send the outputs to different vcos/voices - which are tuned to a reference C from the sinfonion - one really useful thing in the sinfonion is that you can set the starting octave of each channel - both the quantizers (and arpeggiator) and the chord progression sequencer (and the tuning C is in the correct octave) - I also use another sequencer to change song parts on the sinfonion when needed and a clock to advance within the song part
Thanks, now the application has definitely become a lot clearer to me. It's very interesting how a quantizer is used in the different racks
