I’m a big fan of the Dnipro Metamorph and would like something with similar functionalities until they are back in stock - which would probably be a while from now, given they are from Ukraine.
The Metamorph has trigger input which would allow me to advance the sequencer with a trigger rhythms coming from my Dnipro Dot. The only sequencer I know of is the Mimetic Digitalis by Noise Engineering if im not mistaken. Do you have any suggestions?
The goal:
You have also tip-top audio Z8000
most sequencers will do this... they may want 'regular triggers' called 'clock' or 'longer triggers' called 'gates'...
