jb61264
So, what started out as one Rackbrute 6U, grew to add a 3U as well and of course I have filled up both and now have bought another Rackbrute 6U. The images below include what I have so far. I'm considering adding Queen of Pentacles to the second Rackbrute (which will fill the 30 HP remaining nicely) OR the combination of SSF Entity Percussion/BIA/Befaco Kickall (opinions on those options...or a better one?)
I am trying to conceive of a use for the Rackbrute 3U and thinking of some sort of sequencing/modulation unit that sits in front of my two Rackbrute 6Us. Note I also have a Beatstep Pro. I moved the Quadrax + Expander from the 6U above to the 3U and replaced it with the BitBox Micro (on first 6U)...also already had PAMs with the mmMIDI and moved it as well to the 3U
Would appreciate any guidance or suggestions on what to fill up my Rackbrute 3U with. Here is what I had in mind below:
Would love to hear feedback on any and all of the above...
JB
jb61264
Looks like you're having a good time with what you have and would continue to with what you're proposing.
What's your thought on a sequencing / final mix rack? Kind of a beginning and end of chain type of thing?
With the addition of BitBox you also add 8 potential additional outputs and having a clean space to bring that all together could be cool.
If you go with the Hermod (no exp. but read/see good things) does that impact how, when, how often you use other modules that can clock, control, etc... and is that their best use or could a dedicated or just something else work better?
Maybe some/all of this also depends if you're using a DAW or MIDI in someway?
-- Dub007
Hmm...great points of thought for sure. Do you have any ideas for a module fulfilling that mix rack idea? In my studio setup, I have everything receiving start/stop from Ableton, but can also 'drive' from my Beatstep Pro to my modular setup (which has PAMs), but wondering if I can switch that 'drive' control from BSP to Hermod and then use BSP to sequence other things as well but maybe I'm overextending the sequencing capabilities by doing that? Was thinking if I added Queen of Pentacles I could use the drum outs from BSP to 'dedicate' to that module (or the three substitute modules I call out above).
I am in the DAW most of the time now when I'm in the studio but would like to possibly perform at some point without having to taking a laptop (which I currently don't even have because I'm on a desktop in my studio).
Definitely open to suggestions all the way around :)
JB
You were quicker than me :)
Note to self: no posting after 10pm
To be honest, when I first saw the setup my though was Hermod, PAMS... then bring down an FXaid, the Cosmotronic and Caio.
One case for most of your inputs, sequencing and for your final FX and outputs to whatever.
I do think you'll have no problem sequencing all the things regardless what you decide for the drums (all good choices of course).
Cheers!
jb61264
Cheers!
-- Dub007
Thanks for the feedback...Still struggling a bit on what the best 'extension' use of the 3U might be but appreciate the response!
JB
I would lose the kickall and put in a vpme qd, and an erica synth sample drum
