Imagine I have a sequential switch with four inputs and one output. The four inputs are each receiving a different LFO. The output of the seq. switch leads to a sample and hold.
Question:
If I send the same trigger to the seq. switch and the S+H, do I have to worry about the possibility that the S+H would capture the seq. switch output before the seq. switch actually switches to the next LFO?
potentially yes - there is a chance that the switch could be slightly slower than the sample and hold - in all likelihood it will be the other way round though - the answer is to experiment
if you find that you do have this issue then a trigger delay is the answer - either a dedicated one like the doepfer a-162 or in a more general module that can provide this functionality - you can create one in stages, for example
@JimHowell1970 Ah! Didn't know trigger delays were a thing. Thanks!
