Following up on the advice I received from the previous post (https://www.modulargrid.net/e/forum/posts/index/11058). Is this new version nearer the mark? I tried to keep @JimHowell1970 's formula in mind this time. Is this distribution of modulators and utilities more reasonable? Any feedback or suggestions would be welcome!
Everything I do in the rack is pretty much generative, so my feedback comes from that side of things...
Firstly, if you're open to integrating this with a computer, get an ES9 and connect your physical modules with VCVRack. It will open up soooo many ways to learn. I do all my mixing and end of chain effects in VCV, including the amazing and free Supermassive reverb plugin from Vahalla. If you're dead set on a physical only rack, you could even sell on the ES9 when your case is near-full. You'll find a buyer in about 60 seconds after listing it on Reverb.com
Secondly, in your case, you need to increase the randomness (actually the Buchla random you had before would be ideal). I would definitely add dedicated Sample & Holds and put them next to your noise module. Would also add some free running chaotic random CV like a Sloths. Also consider at least one buffered mult.
The other thing I think you need are more ways to attenuate, invert, offset. One key thing about generative is being able to 'tune' your CV in order to precisely tweak that generative randomness into something listenable. One thing you could do isswap some your VCA choices with ones that can VCA but also do inversion and offset. You have a bit of that, but IMHO you need more.
Finally I would sprinkle those utilities all around your case.
Cool idea. I'm definitely not opposed to some computer integration. Still learning my way around VCV, it would be nice to augment the rack, as long as it can stay predominantly physical. I'll have to look into the ES9.
Sloths is new to me. Seems like a bit of an unpredictable beast. Absolutely agree on needing more randomness though, so I'm happy for the suggestion. I often use the O_c for itsshift register/turing machine apps, though I've been on the search for a dedicated piece to replace that and free up the module for other things.
In regard to @HGSynth's comments about tuning modulations, completely agree. Zadar is great because it has that capability built in. I've been using Droid for this purpose for large generative patches because it's a CV modular in the modular, a veritable modular module (yes, does require writing patches in scripts). In fact, it's designs are offset and scaling in every "patch cable". But it's not as hands on as having a stack of 321's but saves cost and hp 4sure.
Otherwise, looks like your "playing surface" isstages and veils, do you find those good for tuning things in?
Thanks@t4mber. I didn't know about the Droid, certainly interesting (albeit a little intimidating!). As far as a "playing surface" is concerned, I'd love to find a solution to allow for more interaction with the system. I've not gotten Stages yet, but the 321 and Veils work well together so far for tuning my modulators (especially with the 321's mixer functions). They're just limited by size. Always looking for recommendations though.
For function generators like Stages, my personal favorite is the Intellijel Quadrax + its expander. 4 envelopes with end of rise and fall triggers plus a CV matrix behind the scenes. IMO this packs more functionality that any of the others, including the mighty Maths. I also use a Befaco Rampage, which is also great and so easy to use but Quadrax is the workhorse. Only problem is there are zero around for sale though I read on one of the German retail sites that new ones are expected in July... I want two!
