I made some adjustments for my techno live setup case.
I am open to feedback if this setup is balanced?
Please leave a comment if I am on the right track here or not...?
Here is the link> ModularGrid Rack
Cheers
and thanks
no link?
no still mostly the same problems
especially the mixing solution... the queen of pentacles is stereo out, the furtherrgenerator is lots of mono outputs of individual waveforms - these might need mixing, the godspeed has 2 mono outputs, the desmodus versio and the arbhar are stereo
other than the veils - good choice of vca btw, the cockpits are allegedly stereo, but on single jack (no idea how that works), feeding rosie, a stereo output! do you need a load of stereo cables that are specialist, either mono->stereo, or single stereo cables??
it just fails to work properly - no ability to sub mix waveforms - except for what's available onboard the actual vcos, no ability to convert mono to stereo... there's no panning - so the mono sources are only ever going to be hard left or hard right... no where in between...
&amp; no filters?
Thank you JimHowell1970 for the feedback.
What would you suggest I do, what modules I need to look at and maybe take away?
Cheers
ThePlate
How about forsaking the Erica mult for, say, a sub-mixer or two for the voices, and then a good performance mixer like the Roland 530 or 531? Some arrangement like that would fit in your case. Otherwise just get the wmd performance mixer. It is the best.
Small submixers: https://www.modulargrid.net/e/modules/browser?SearchName=&SearchVendor=&SearchFunction=6&SearchSecondaryfunction=&SearchHeight=&SearchTe=8&SearchTemethod=max&SearchBuildtype=&SearchLifecycle=&SearchSet=all&SearchMarketplace=&SearchIsmodeled=0&SearchShowothers=0&order=tag&direction=asc
Thanks for your input ThePlate.
I saw the wmd mixer, looks really practical and the Roland 531 is also a nice module...also bit cheaper then the wmd i think..hehehe
The Cockpit from Endorphins is also a 4 Stereo Channel Performance Mixer, so that is then 8 channel i have then in the rack, i have 2 of them.
So i need more then that to make the workflow better?
personally I like the tesseract tex-mix over the wmd performance mixer - it's significantly cheaper and more expandable and uses less power - I'm sure that the performance mixer is exceptional - but it is big and expensive and power hungry...
the advantage of these over the cockpit is that they have panning for mono sources to stereo, in the case of the wmd pm, this can be automated with an lfo*) - which allows you to put a mono source in the middle, fully left or fully right or somewhere in between - if you only have stereo inputs - then you only get the possibility of fully left or fully right - or both if you mult the signal (and then recombine using a special cable in the case of these cockpit modules)
the only "advantage" of the cockpits I see is that they have ducking - although imo this is better patched using envelopes, an inverter/polarizer/attenuverter, a small utility mixer and a vca - ie "modular synthesis" and not just "synthesis with modules"...
I see the 'mono/stereo/ios send/return' nature of these mixer modules to be a complete pain in the arse... I seriously would not want it in my rack... I'd be loosing any adapter cables in the pile of patch cables and/or confusing stereo cables with regular patch cables and wondering why my stereo field was competely shit constantly - ymmv, though
the cockpit modules only really stand up in a endorphin.es only set up and if you are willing to separate audio and cv - which is one of the advantages of eurorack over some other formats, in that it doesn't do this...
BUT saying that either way you need some smaller mixers like the 3*mia or shades or whatever - to use as sub-mixers... and then you get back to the mono/stereo patch cable malarky...
also at least one filter is a good idea - there are so many available and they are so personal, that I find it difficult to recommend them - I have a couple of ripples - which are rolandy/vanilla, various doepfer ones that are based on other classic filter designs (wasp, sem, moog) and a couple more - but they all impart their own characteristics and it's impossible to say x is better than y - as it's so personal - there are plenty of filter shootoout demos on youtube, which should give you a basic idea - what to look out for
*you can do this easily with a mult, a couple of vcas, an lfo and an inverter - if you want to patch it when needed - or buy cv-able panner modules if used constantly
ThePlate
Jim speaks truth, the Tex Mix is a really good option, definitely more suited to this particular rack then the WMD ; )
