Might be the one ☝️
You could definitely have some fun with this bad boy, no need for a mult from what I can tell though, I'd add an HPO to make life simpler.
Definitely not "the one". However...
Now THAT'S "the one". What's going on here is that I first changed the order from right->left to left->right...makes it easier for me to build, and you can flip this back to the R->L one.
Then, after the uZeus, there's now an actual modulation section. Four freerun LFOs, four loopable AR envelope gens. The huge Doepfer quad VCO got turned into a Studio Electronics Quadnic. Then Veils serves as your modulation amplitude control and mixing (yeah, I even had room for VCAs here, too!), your Wasp is next, then the FSU. And for output AND your headphone preamp, a Befaco OUT v.3 which also has stereo balanced TRS outs, and a patchable cue send.
The big takeaway here is that while these little skiffs are really a total PITA to build, it CAN be done...but you have to be careful about module sizes in order to be able to fit all of the functionality you want. Well...provided it's not something that requires buttloads of modules, that is. By tossing the Doepfer Quad VCO and Maths (which took up 38 hp between them...in a 60 hp skiff) and being careful about module selection with regard to both function AND ergonomics, this opened the build up sufficiently for all of the new toys.
And the bonus? It only costs $22 more than your original build! Not too shabby...
I have a grandmother,mother 32,DFAM and Subharmonicon so am looking for useful bits to use with these.
