Adding an offset to your signal requires its own attenuverter to be put in the chain with -5v to+5v available unless you stack more attenuverters together for greater offset
quad attenuator, attenuverter, mixer and DC voltage source
https://intellijel.com/eurorack-modules/quadratt-1uAdding an offset to your signal requires its own attenuverter to be put in the chain with -5v to+5v available unless you stack more attenuverters together for greater offset
-- jmettlew
Without a source plugged into an input, each attenuverter generates its on static CV voltage. You can add an offset by summing two adjacent inputs together, like A&B. Run your source signal into A and adjust to taste in either uni or bipolar. Then take your output from B. Adjust B in bipolar mode to add an offset. I suppose if you want greater than five volts then to tap at C. B and C should sum...
Maybe I'm not understanding your statement or question.
