Hi all,
I've had an Arturia Minibrute 2s for a few months now and am hoping to delve deeper into the modular synth world. I'd love some feedback and help getting my head around my future rack (ie what I'm missing/what would be better for the sounds i'd like to make. I want to make heavy, gritty techno. for example music like:
=a926bf990cb042fe9ff425a93ec9ead5
anyway here is where I'm at with it.
https://cdn.modulargrid.net/img/racks/modulargrid_1763004.jpg
Any Help/feedback would be great.
Would also be interested in what modules i should buy first.
Thanks
Alex
Visit some of the other "first rack" threads. The biggest issue in almost all of those racks is the SIZE of the rack. They are too small. Skiffs should be built by people who really know modular well. To build a GOOD skiff, you have to make trade-offs on your modules considering size and features. My analogy is that it's building a classic Swiss wrist-watch versus a grandfather clock. The wrist-watch is much smaller and the tolerances are a lot tighter. You're going to get into a lot more trouble building the wrist-watch coming into it with no experience.
The first thing that is problematic is the control of your synth. Plaits requires a pitch CV and a gate CV play, so does your BIA. Every Erica drum module requires a gate/trigger to play. Where are all of these triggers, gates, and CVs going to come from? The MIDI module you've dropped in is very basic and can't support that many modules itself.
Speaking of the number of modules, how do you intend to get every sound generating module to your audio outputs? You can use the Maths as a basic mixer. But that's a huge waste of a Maths module. You have two oscillator-type modules, drums, a noise module, put some time into picking out at least one basic mixing module. You might want something basic that can handle audio and CV... and then maybe something a little better that can handle stereo audio.
It's been stated "you can never have too many VCAs." You have too many VCAs... for the size of this build. Plaits and BIA have their own internal envelopes and VCAs as well. You don't have to use them, but most people do.
I have DATA and I have Maths. But they are nice-to-haves in a Eurorack case. For a skiff, they are just too big to justify in most cases. But again... why skiffs aren't a good idea for your first build.
Also, the 2HP stuff should be integrated sparingly. The tiny knobs are tough for big fingers to adjust accurately. Also, if you place them next to each other you will have a really hard time not bumping the settings for an adjacent module. You'll find in Eurorack, that tiny adjustments can be the difference between a sound that's garbage and one that takes your breath away. Ergonomics is a real thing. With 2HP modules you also have to keep careful track of your power consumption as well as the DEPTH of space available in the case. 2HP modules can run pretty deep in order to keep their 2HP width.
I hope this reply was helpful. If you bought this set-up as-is, you'd probably be disappointed.
+1 for everything @Ronin1973 said!
User left
Hi,
I am experimenting now with smaller case setups but have much larger cases for most modules and the challenge is to have enough room for a meaningful setup while still being user friendly. Have you considered a Tiptop mantis case? That would give you two nice wide rows with enough space for a good basic setup and yet remain portable. For my portable rig, what I am planning is two cases: a Doepfer 6u suitcase that gives 168HP for larger modules and a small Intellijel 4u palette case. Even then, I still need to plan carefully and cannot fit a lot in that space. I dislike 2hp sized modules as the knobs tend to be difficult to use in patches. Case in point, my 2hp Cat module while fun is difficult to manipulate when fully patched. A slightly larger 6hp sized module is much more comfortable and easier to handle for me with my fat fingers lol.
Hmmm...the solution to the case issue is actually right in front of you if you still have that 2S: an Arturia Rackbrute 6U. It fits above the 2S via its special bracket/handle setup, and it'll deal with this present build's issue of a too-small cab. I would suggest implementing that with less audio modules and more modules that can throw the 2S into sonic conniption fits: modulation, clock tampering, logic, etc.
