I have the QD… hard yes on Qex!!
Quad Drum Expander
https://www.youtube.com/watch?v=4MqQj_lO-7cHard yes, indeed! I‘m curious about the other thing(s) it does except audio outs and CV ins.
Damn, I need this and was contemplating a filter to separate voices by pitch... this makes a truly outstanding module nearly perfect!
Elevator Sound in the UK has it listed on preorder, and the manual is available from the VPME website.
any news on this?
-- neykes
it is now available at Thomann
https://www.thomann.de/intl/vpme.de_qex.htm
any news on this?
-- neykes
available at schneidersladen (Germany) as well
https://schneidersladen.de/de/vpme-qex-quad-drum-expander
Module depth:
33 mm without power cable
43 mm with attached power cable
Just got one of these QEX modules from Perfect Circuit. I was hoping the instructions had an actual picture of what connects to what exactly. It say to install centered on the pins and is easy to get wrong, then says do not connect the wrong way because damage may or will be caused to module. Also make sure not to bend pins. Anyone happen to have a picture of the connections with arrows showing what goes where? Thanks for the help.
...Anyone happen to have a picture of the connections with arrows showing what goes where? ...
-- Thyratron88
hmmm
qex has to be right of QD main module
there aren't that much possibilities to align the connections!?
see the picture on https://vpme.de/qex/
*EDIT
the 16 pin connector has a POWER label at the bottom.
This indicates the position of the -12V / red wire of your ribbon cable
