I'm trying to put together a 60HP minimal techno drum setup with the Flux as my trigger sequencer. It can double as a modulator for a few of my drum modules and I have 4hp left. The WMD Fracture isn't viewable on this setup for some reason, so please keep that in mind. Is there anything you can suggest? I'm not closed to subtracting a module and adding something else you might find more fitting? Thanks for taking the time to read this post.
Here's my setup so far: ModularGrid Rack
the modules appear to be dwarfed by the controller - almost an afterthought
if it was me bigger case, bigger modules - better ergonomics, better synth...
looks very low on mixing capability th eamix only has 3 channels and you have 5 + of drums
try refreshing the rack!
