lvbeethoven
Hello,
I am looking for a module that can reverse the curve of a signal.
For example, as if I placed a mirror on the floor and reflected an object on it. A horizontal reversal of the wave.
an illustrated example: https://i.servimg.com/u/f90/20/36/39/92/captur12.png
Thank you for your answers :)
TumeniKnobs
The image looks like it has a 50% phase offset in addition to mirroring the wave. If it’s just a “mirror” you want wouldn’t a standard inverter do that? Maybe I’m missing something.
I don't think you are missing anything
to mirror a positive waveform to a negative waveform a standard inverter would absolutely do
for the phase offset a short dc coupled delay would work - but if the frequency of the waveform changes the so will the phase offset - so may not be a viable solution
lvbeethoven
Thanks for the answers.
The screenshot: the offset is normal. Sorry for not clarifying that.
Ok, I'm going to look for the inverters.
