No user found with username joazinho
There seems to be an interesting mistake on the panel. It says that if gates 1 and 2 are LOW it will be in LPG (LPF + VCA) mode, which makes no sense.
When both gates are low nothing will happen. :-)
do you have one??
i do but I've never tried using the gates before - it definitely does something - there is audio output when both gates are low - but there is too on both gates high which is undocumented
00 does make sense to me - based on reading the manual and understanding a bit about how the underlying circuit probably works - I am playing with this now - I'd say both high and both low are LPF+VCA
think about how switches work - 3 position switches are on/off/on... and low/low is off
