Hey!
I put this case together for my Techno live show and I wonder what other people think about it, what they would change/ improve and I just want to hear a second opinion about it.
The style of Music I love is from Artist like Oscar Mulero, Stef Mendisidis, Sleeparchive ....
Its a 104hp, 4u palette case from Intellijel.
The plan is to use the the 1u Midi to control 2 synths, and use the CVx to send Trigger and Accent to the Drum Modules.
https://cdn.modulargrid.net/img/racks/modulargrid_1338428.jpg
Looking forward to read your opinions!
Max Brosamer
zuggamasta
There are some nice things in your build but I'm not sure how far you'd come with it. And you still need the HRAD "main section" to go with the PRAGA. As it doesn't have any way to out put it's mix without the HRAD.
https://www.modulargrid.net/e/xaoc-devices-hrad-
Thanks @Zuggamasta for your reply.
I'm pretty sure Praga has a mix out in the middle bottom of the Module, no Expander needed for that.
Max Brosamer
zuggamasta
Yeah I'm blind. Sorry for that!
But the expander has some nifty addons! ;)
The palette case has jacks for line level inputs and outputs. You have to BUY the modules to make this functionality work. Your modular gear works at SYNTH level, which is a lot higher than line level (your Octatrack). You're also going to need a MIDI to gate/CV converter. Again, the Intellijel case has the facilities for MIDI, but you have to BUY the modules to connect to it.
So you have a Palette and two 1U modules for MIDI and audio IN/OUT and you still haven't put in anything synth or percussion related yet.
You'll probably find that buying a drum machine and plugging it into the Octatrack is probably a much better option in terms of set-up and price.
