Hello , im new in the world of modular.
This is my set up, its possible some tips.
Thanks
what sort of tips?
which of these modules do you own?
what sort of music are you making?
what other gear do you own?
I have all already with MDLR PORTABLE 12U/104HP box, I need some bases to start.
Music Techno more melodic ambient.
Have some voltas micro freak, some delay and reverb pedals. This type of gear, nothing modular.
Have already made some music with the módulos i have.
What Type of utility modules?
-- darksoul
if you are referring to my signature - effectively all of them - mixers of all sorts, vcas (especially cascading ones), switches, attenuverters etc etc - use for modulation and triggers as well as audio - doepfer almost always has a reasonably priced version of everything (but it looks like you know that already)
-- darksoul
Can you give some ideias, the first ones o should buy first?
CardiacTasty
I'm pretty new myself, but I can already say any modulation source (lfo's, envelopes) almost needs attenuverters/vcas to tune how deep the modulation will go. This is particularly true for voices that have a wide range of responses across a single knob (Noise Engineering modules almost always have wild responses to tiny knob adjustments, for example).
For attenuverters specifically, I think the Steady State Fate's Quad-Atten looks great. I have ALM Busy Circuit's ALM010 - O/A/x2 and it works like a champ for so many things (pitch before a quantizer, normal variables).
CardiacTasty
I should say I'm trying to build a portable techno system myself right now, getting a lot of great advice from others here.
One particularly transformative bit of advice: the Metropolix is a beast of a pitch sequencer. If you're trying for two voices (maybe a lead and a bass line), the Metropolix is a solid answer. I'm buying one myself.
Another transformative bit of advice: an external drum machine works really really well. You have a lot of space with this case, but my guess is you'll find space runs short incredibly quickly. An external drum machine saves a tremendous amount of space, and a tremendous amount of money as well. Plus, you know, they're fun.
Are you sure you want to have a dual purpose of melodic techno as well as ambient with this build? It seems like one of the consistent pieces of advice I run across is to focus your build on one area; build it to do one thing really really well before trying to cover more bases. Noodling around with modular is plenty of fun, but if you want your build to actually make good music in some specific genre, build for that genre in mind.
-- CardiacTasty
I have one microbrute{external Drummachine], techno and some experimental music That is my ideia].
It was very helpful some tips from the ones have murcha more knowlege.
Hello,
Since de Mutable intruments (grids) is discontinued.
What is the best alternative?
Thanks
klodifokan
Hi,
This one could be interesting :
https://www.modulargrid.net/e/blue-lantern-modules-grids-mk2-2021
Cheers
Hi,
Cheers
-- klodifokan
Hi,
Cheers
-- klodifokan
Thanks
klodifokan
Hi,
There is one available here:
https://reverb.com/fr/item/40737363-blm-grids-mk2-2021-12hp
Directly from Blue lantern.
Cheers
