wishbonebrewery
First patch with Acidrain Chainsaw, heading through HNVCF and Omsonic FLF before hitting Make Noise Mimeophon (Clocked). Feels like a match made in heaven, now I want to get a stereo filter like a Stereo Ripples or I bet a Patching Panda Moon Phase would be amazing. Patching Panda Punch VCA in use here too. Marbles for gates and pitches.
GarfieldModular
Hi Wishbonebrewery,
That synthesizer sound, the leading voice, wow, what a sound! That's great, sounds quite J.M. Jarre-ish to me ;-)
Nice jam once again! Thanks a lot for sharing this with us and kind regards, Garfield.
farkas
Sounds great. Definitely has a Jarre vibe. Keep sharing the good stuff @wishbonebrewery.
I use that Patching Panda Punch in every patch nowadays. Such a valuable module.
BTW, if you're actually aiming for the Jarre sound, you'll want a couple of these laying around: https://reverb.com/item/40898075-electro-harmonix-flanger-hoax-flanging-phaser-modulator-pedal?bk=eyJhbGciOiJIUzI1NiJ9.eyJqdGkiOiJkMzk5N2U1Zi04YjU2LTQ0OTUtODA5NS1jMTZlZWE4NjQ2OTMiLCJpYXQiOjE2Mjc5NTQ3NjAsInVzZXJfaWQiOiIiLCJzZXNzaW9uX2lkIjoiYjAyZjYwMjgtNjQ1Ni00ZjYwLWFjMjEtOGU1ODBhODEzNTY3IiwiY29va2llX2lkIjoiNGY3NTU5NjItMzc5Mi00NDQzLTk5YWMtYjZhZDk1MjlhOGNmIiwicHJvZHVjdF9pZCI6IjQwODk4MDc1Iiwic291cmNlIjoiTk9ORSJ9.YQfCt-43lTDncYnf3c-l7-Jetvd2eHW-69wFtX_hh4w
Geez...I hate it when it does those gawdawful long URLs. Anyway, what that is is more or less a clone of the old Mu-tron Biphase, which pretty much no one can afford now. And while E-H recently discontinued this pedal, there's plenty of them on the used market still...although, the used prices are starting to look like what I paid for mine NEW, so if you want to pull the trigger on a couple of these, I'd suggest moving a little bit quickly. Anyway, Jarre's classic string-wash phasing (like on "Oxygene") uses a pair of the Mu-tron units for left and right channels of his string synth, sweeping out of sync with each other. The Flanger Hoax should get you to where that lives, though.
wishbonebrewery
I should probably say that each of the filters is on a different Stereo channel, that may or not be obvious with the Mimeophon set on Skew.
@GarfieldModular - Thanks, I need to look at working on something more slow in progression.
@Farkas - Punch is great, great for plucky blips and filter ascents, and sooo good for dirty acid lines with the Rebach VCF-AB.
@Lugia - The worlds longest URL courtesy of Reverb :) I'll have to have a listen to some Jarre see what you mean, I'll admit I'm not a massive fan of the Phaser sound but if it works in Oxygene I'll check it out. Cheers
jtunes_ia
GarfieldModular
Hi Lugia,
The Mu-tron and the mellotron are that about the same thing or two totally different things?
Not even close. The Mellotron is the tape-based "protosampler" that defined a lot of music from the mid-1960s up thru the end of the 1970s or thereabouts. For example, the opening of "Strawberry Fields Forever"...those are the flute tracks from a Mk III. Great instrument, maddening maintenance requirements.
Now, Mutron was a spin off from ARP and they put out effects pedals that are VERY sought-out to this day. The Biphase was this amazing phase shifter that employed both swept and fixed/tunable filters and some really interesting modulation methods, and the original developer collaborated with Electro-Harmonix when they designed the Flanger Hoax. Flanger Hoaxes are a bit spendy, but NOTHING compared to the price of vintage Mutron gear!
farkas
If I remember correctly, Butch Vig and Billy Corgan half-jokingly said the Mutron Biphase was their secret weapon when recording Siamese Dream.
GarfieldModular
Thank you very much for the background information Lugia! Always nice to read such information and very informative :-)
-- farkas
Yep, I think I remember seeing the same interview some time ago. And the Biphase is definitely something Butch Vig would glom onto. In fact, I don't even see a regular version of it on Reverb, just a reissue for $670-ish. But they DO have a hyper-rare Mu-tron 3X modulation filter/effect pedal there for only...ok, get the oxygen ready...
...$20,000.
