Hello all
I just got a Erica Synths 2x84HP case with PSU.
Their website states that "This case has integrated Erica Synths PSU capable of 1.25A per rail (2.5A total)."
But looking at the PSU, a Mornsun URA2412LD-30WR3 it says OUT ±12VDC / 1250mA
I'm afraid of burning my brand new modules and their support seems to be a bit slow on replying.
Anyone with a similar case can shine some light please?
GarfieldModular
Hi Oldan,
Not sure where the issue is? I don't see it to be honest, as you mentioned already:
And then you checked your PSU (good by the way to check!) and you found this:
OUT ±12VDC / 1250mA (thus -12 V at 1250 mA = 1.25 A and +12 V at 1250 mA = 1.25 A, together 2.5 A; I assume, unless the manual of that PSU says differently)
So that's the same, isn't it, so... where do you see an issue? Did you bought this Erica Synths case new from Erica Synths or an authorised Erica Synths dealer? If yes, then this should be fine.
You could start with one module, then two, etcetera, in case you are still not sure but I don't see an issue.
Have fun with modular and kind regards, Garfield.
1A = 1000mA
Hi Oldan,
-- GarfieldModular
Thank you for the explanation, I don't know much about power technicals.
In the meantime Erica support replied and confirmed its all fine, its 2500mA in total.
