Hi,
I am building up a dedicated case for the drum modules. It hosts the drums, effects and a 6 ch mixer. I drive it via an 8 track sequencer.
Now, i was wondering what could be the best solution to patch everything so that i can just switch some cables if i want to swap some sounds or effects without having to unpatch/repatch everything.
Usually, in the past, i would have used some patchbays to do that.
The only module i come with is https://www.modulargrid.net/e/addac-system-addac911 but it's 1u and i don't have a case to host it.
Anyone has some suggestions?
thanks
regards,
Matteo
GarfieldModular
Hi Matteo,
How about the Erica Synths' Link module? That's a small version of your mentioned 1 U ADDAC911 module.
Might be that one does the trick for you?
Kind regards, Garfield.
Hi Garfield,
Thanks for the tip. This is can help, yes. I guess i can use this in combination with some passive multiple to build the final solution i am looking after. Thanks. Matteo
You could also get this done with a switching mult...something like the Doepfer A-182-1 comes to mind. This gives you two passive mult busses as well as a center "disconnected" position. EMW also makes a switch matrix along these same lines, albeit in a 4 x 4 matrix (plus a couple of regular passives).
Good stuff, thanks Lugia
