I’d like to share what I have in mind for my rack. It has two voices plus a Oneiroi for drones, with Pamela’s New Workout handling clocking and Gamut Repetitor handling sequencing.
Instead of expanding the rack with drum modules and a “proper” sequencer, I’m thinking of adding a Digitakt and connecting it to the rack via an ALM mmMidi. I’d route the rack’s audio through the Digitakt and then into my audio interface.
That way, I’d still have Pam and Gamut in the rack, and I could use the Digitakt to sequence two Eurorack voices via mmMidi while also handling drums and any other sounds I want to add. I’d mainly use the combined setup for techno, and I’d still be able to play the rack on its own for ambient and dark ambient.
Does that sound like a good setup? Do you see any issues or anything that might be awkward in practice with this combination?
I’d love to hear your thoughts, especially if you’ve used a similar setup.
Cheers,
NoSky
Hi, i 'm doing more or the the same. Even if i don't do techno anymore.
Currently i'm testing a 6u 88hp case with the portail by eowave. On the sequencing side i use many elektrons.
I would say to drive a synth you should focus on an elektron that have midi arp and midi retrigs and there's not a myriad of them.
Currently there's octatrack (it has midi arp but not on the audio tracks) and tonverk.
here's the rack i built
i have tried many configurations and i always find a 104 hp case for live is overwhelming to me.
this is a simpler case i'm willing to improvise, i keep the other case ( a mantis ) for studio use ( it's full of modules too) and the moog 60hp case.
i think it's a great idea to offload the sequencer and drum duty because i don't like any of the sequencers i tried in eurorack, and druming in eurorack is cool but takes a lot of space and modules.
so this is it tonverk+modular and digitone2 for polyphonic duties
thanks for you post holografik
so, you would recommend octa instead digitakt just because it has an arp, is that correct? i think if you wanna go with arps i would buy the noise engineering "opp ned" module for arp generating in the case itself combined with the garmut repetitor... i like the digitakt more than the octa or the tonverk, the handling with octa or tonverk a a bit to overwhelming for me.
PS: i think this is anyway a strange thing, that digitakt has no arp... thats a bit annoying..
i wouldn't recommand octatrack, old cluncky workflow for me, in fact digitakt is fine because there's many ways to generate arps as you said. the portail have some midi effects also i just recall now.
