https://cdn.modulargrid.net/img/racks/modulargrid_3257126.jpg
Just trying to make a compact rack, 62 hp intellijel pallette, only interested in intellijel modules (hometown bias).
Will exernally sequence and process 2 voices. Just trying to get 2 analog synth voices. Does this setup make sense?
Would be good if you can cram in a LFO. Maybe instead of that L - R OUT? You can go straight out through the VCA.
It's somewhat 'normal', in the sense that you could buy a two voice monosynth and it would more or less have the same functionality. if that's what you are after, I believe all the building blocks are there.
The USP of Eurorack is that you can get weird and wacky building blocks. That's something you could think about down the line if you'd like to add some more experimental/generative/logic/whatever building blocks.
Hey thanks, yeah I'm basically looking for a nice analog bi-timbral synth but I haven't found much that fits in this form factor.
An analog bi-timbral synth would have to have every part twice, so it would definitely be a premium model.
A sequential switch would allow you to make two timbralities/patches and switch between them. You'll likely want both voices for most of your patches. To stack, to FM, to sync, etc.
