noodle_hut
New plan and build:
![](https://storage.googleapis.com/modulargrid.net/easymde/227314_42b3df512bbd91a044e7d891c48416e2_1733946669.png
Looks like quite the fun system. Out of curioustiy, how do you like the Panharmonium and SIG+? The Panharmonium is on my wishlist, would love to know if it lived up to your expectations/thoughts about it. The SIG+ I have in my rack, but it's definitely a module you have to spend some time with to understand. Curious what your takes on them are?
noodle_hut
For me, the Panharmonium is its own thing. It has its own idea of harmonics and doesn't play well with others if you want things "in tune". The Doepfer frequency shifter is also kind of like that. I use the mini synth voice after the Pan to tame it and maybe chop up the output. That said, it makes sounds like nothing else and when I use it, it dominates: "this is a Panharmonium piece". I'm still learning it, but it's challenging.
Because the stuff I do is almost always auto-generated, the SIG is usually my starting point. I just love it. It's always good for making those moments where you have to stop and listen in wonder at what it's doing. I have the two sequential switches after it so I can use SIG as a selectable chord bank. I'm sort of slicing the four channels sideways into a single channel, then use the adder to transpose the key, the switches to select the bank. That CV/gate pair then gets split back into four pairs by the Shifty, envelopes are made and then it all goes up to the Mob of Emus, VCF'ed, VCA'ed, and out. Takes a lot of wires to set up the patch, but holy smokes, it sounds amazing.
The three thru-zero VCOs section in the lower right is a new idea to play with FM. It’s not quite there yet, but getting close. The OXi Coral is also new. It really wants to be fed by midi, so I use the Befaco CV Thing to give it 8 analog inputs, giving me eight voices in a small space. You can see there’s also the midi i/o from the NerdSeq directly to the left of it. Shows promise.
The NerdSeq. sigh. I use it all the time, and it can do a thousand things, but the interface makes those thousand things hard to find and use. Ten pounds in a one pound sack. It really needs another interface layer on top of what’s there. Clearer documentation would help as well. It reminds me of programming in assembly language. Tedious. A love/hate relationship with that one. Same with the Disting, but for different reasons. If you’ve got one, you know.
I really like the clock section in the lower left. Gives me everything I need including start/stop and reset. One button starts the whole thing. That Multicore there has two ribbon cables on the back that mirror to the other Multicore on row two. Saves me from draping clock and control all over, and the RJ45 connectors still work to bridge to other boxes. Glad that I read the manual for them. And the QAM multiples are great. Well made at a good price.
I’ve got nothing too exotic, very meat and potatoes compared to most setups I’ve seen here.
It's such a cool concept and all of the videos I've seen sound really wild. I can kind of see why it might not be great at blending in with the crowd, though, as you say. I have the Assimil8or and the sound quality and intuitiveness of the interface is out of this world, so I'm very keen to experiment with a differnt piece of Rossum gear. The Doepfer frequency shifter I've also had my eye on (shame about the price); I can only imagine how much it helps in a patch.
That is an insanely neat patch. I'm still in the "trying to remember what button combo does what" phase of learning the SIG, but the potential is clear. I love the idea of essentually improvising a duet with the synth.
-- noodle_hut
It's the meat and potatoes that get the job done. The fancy garnishes can wait.
