Part of larger patch some stuff could definitely be simplified down.
Generative Parts:
Disting EX
- DUAL Mode - F6 Quantised Random
- Pentatonic Minor
- output (pitch) A sent to input 2 of buffered mult 2.
- Gate output sent to WMD Switch.
Disting MK4
- H2 - Dual S&H
- Noise fully added to X and Y,
- SLEW set to max to generate smooth random voltage.
- Outputs A and B patched to dual buffered mults input 1.
Pamela's (Clock)
- Main clock set to 120 BPM
- Output 1: 4x Gate - Sent Disting EX - Shift Register - X Input(Trigger)
- Output 5: 4x Gate - Sent to Disting MK4 - Z input(Gate) - Dual S&H
- Output 2: /4 Gate - WMD Sl3KT switch
WMD SL3KT Switch
- SW1 - CV Select from Pam's Output 2
- SW1 - Output A - Stages - Gate in Segment 5
- SW1 - Output B - Nothing (in larger patch this goes to Rings - Strum)
- SW1 - Input - Disting EX - Shift Register Gate output (B)
Buffered Mult 1
- input 1 - S&H Outputs
- all outputs normalised to input 1
- Stages - Attack (Seg 5 -Time/Level )
- Stages - Decay (Seg 6 - Time/Level)
Bufferd Mult 2
- ONA FM, ONA PW
input 2 - Pitch outputs
- ONA 1/V
Sound Parts
ONA Oscillator
- 1/V Pitch coming from Disting Shift Register via Buffered Mult
- FM and PW modulated by smooth S&H via Disting MK4 (Buffered Mult)
- Octave set to 2
- Saw wave Output sent to Vult Freak Filter
Vult Freak Filter
- in stereo mode (being used in mono)
- Set to Tangents Low Pass Filter
- Cutoff modulated by Smooth S&H
- input from ONA
- output to VCA
Stages
- AD envelope (Segments 5&6),
- S&H modulating Attack and Decay Times
- Gate from WMD Switch
- Envelop out to VCA
VCA
- input from Vult Freak
- CV in from envlope generated by stages
- Out to mixer channel 1
Mixer
- Send 1 to FX Aid in BigSky Reverb Mode
- Master Outputs to main external mixer
- Channel 1 is fully wet to send 1
