So this is the 4th rendition of my past modular builds. I decided to go with a 104hp Moog case, something simple to start with because I'm new to the world of modular. I was looking for basic basic BASIC stuff to start with and still have plenty of functionality. Eventually I'll make a second rack with the same case and power supply so I can daisy chain them together, but that's a couple of years away. So for now, I hope this is enough to start with.
I think you'll have fun with this rack for awhile and learn a lot. One suggestion: I personally wouldn't duplicate modules this early, instead add an STO or a Dixie II+ so you get a little variety in your analog oscs.
Once you get started let us know how it goes!
@troux
Can i use the quad vca as a mixer??
yes you can - it says so in the description
"Quad Voltage Controlled Amplifier and Cascaded Mixer"
the important part is "Cascaded" or "cascading" - if a multiple vca says one of those 2 then it is also usable as a voltage controlled mixer
