Hi,
I´m currently looking into combining triggers from diferent sources to drive e.g. a single drum voice.
As i read through a lot of threads, i get that a logic module (especially an OR function) would do the trick on a basic level.
Than i came across this old video from mylarmelodies
He uses a switched multiple to combine triggers into a single output. This way he´s able to toggle different trigger sources on and off - which i think is pretty cool.
Now, my actual question is, if this use of a switched multiple is more or less "safe"? I read multiple times, that modules could be damaged when fed combined trigger voltages (e.g. 10 v).
Can anybody confirm or deny that?
Moreover, can you think of another method to achieve the same? (being able to switch combined trigger sources on and off)
Thanks for any help in advance!
