Discovering any Bugs? Post here!
-- modulargrid
There is a Lazy fly in our home office, its probably going to die as its that time of year.................
There seems to be a bug with My Modules feature. I've added quite a few (40-50), initially just three of them appeared in the tab. I logged out and back in, and then it seemed that most if not all of them were showing up. Then on following login just a single module is now showing up. Would be great to resolve this issue as it was one of the features that prompted me to upgrade to paying version. Thanks
-- soulsun69
If you go to the My Module section the search parameters still apply. Click Reset in the search form and check if the missing modules appear. Does that fix the problem?
Not sure if something was just being changed but that 'Legacy Mode' button just showed up as a 'Toggle' button and the reply input form was stopping me use all of my letter keys, some worked and some didn't.
Weirdly now this seems OK again. Must have been a Glitch in the Matrix-mixer!
I don't know what the sparkles next to some manufacturers' names (like Xaoc Devices) mean, but in the module list they flicker incessantly on my iOS devices... is that intentional or broken? It is very distracting.
Bug report is for half-height modules in Buchla - I know they're more or less discontinued at Buchla, but there are still some third party manufacturers (Norhthern Lights) that do some.
Basically, the disorganization cat will sometimes show up, even though you half the half height modules in the right place, and save / reload of a rack will move them around, sometimes stacking them both at the top of the full unit, then mistakenly saving modules in the same slot.
Not sure if this is a bug report or a feature request so apologies in advance.
Email notifications that I receive are following my browser/email client dark modes changing the text colour to white (or thereabouts) but the background remains white making the text close to unreadable.
-- eastwood
I don't know which email client you use but I have now deleted all color settings from the mail template so your client might work better?
Found some querying inconsistencies in the Module Finder when it comes to modules listed under the "Other/unknown" manufacturer:
  • go to Modules
  • as an example, type "corruptelam" in the Search box, don't modify any of the other search criteria
  • note how the module is not found
  • then select the "Other/unknown" manufacturer, now the module is found
  • feel free to try out with other module names (e.g., "fluxus duo"), you'll observe the same behavior
It seems the modules listed under "Other/unknown" are only found when you also select this manufacturer whereas expected behavior (by me) would be that these also appear if you just search on their name only and leave the manufacturer blank (-). Which is how it works for all modules that are attached to their actual manufacturer (e.g., I can search for "koszalin" and get the correct result even without selecting "Xaoc Devices" as the manufacturer).
-- drohn
"other/unknown" is excluded on purpose which makes sense to me.
There is a hint when you have 0 search results as well:
-- drohn
-- modular01
Ah indeed, honestly hadn't even noticed that yet. To me, it doesn't make sense if you enter the actual name of the module in your search criteria, but anyway: problem solved. Thanks!
-- modulargrid
The primary version of KOMA Dual Discrete VCA cannot be added to a rack. Choosing either version from the module page adds the alternative version picture. This started some months ago. Before that it worked fine.
Hello,
The font size on Microsoft Edge is too small for the entire website, almost unreadable. It looks like the website thinks my screen is huge, which is not the case. I am not sure if this is a bug or some sort of cache issue. But I haven't found anything in the cache. It used to work normally before, but something got broken. Any idea on how to fix it?
The font size on Microsoft Edge is too small for the entire website, almost unreadable...
-- electricfish
Ensure you have 100% zoom. I think the symbol in your address bar indicates a non standard value.
maybe you changed it unintentionally with Ctrl + mousewheel
common keyboard shortcut for 100 % zoom is Ctrl + 0.
those shortcuts should work in most web browsers
It seems like the Mutable Instruments Plaits page has disappeard, although the module is still listed in the Module Finder.
https://modulargrid.net/e/mutable-instruments-plaits
