mikeleebirds
What happened to the photo? It used to be correct, but now the crop is wrong.
Something is wrong with the rendering on all the 1U tiles.
mikeleebirds
Weirdly it looks correct on my iPhone, but not on my iPad..
exper
Switch to the second image using the blue arrow buttons. The originals that I uploaded had a small border on the top and bottom so that the fit properly.
mikeleebirds
I do not see that option.
exper
-- mikeleebirds
Once the module is in your rack, click it once to see it’s options. You should see two blue buttons on the side that cycle between any option images for a particular module.
Like this:
https://www.dropbox.com/s/b0v8yf14fdbq6v2/buttons.JPG?dl=0
modulargrid
-- mikeleebirds
Make sure Panel Selector is active in the top right action buttons.
-- johnnn
1U tiles don't share the same format. ModularGrid uses the specs from PulpLogic. They differ slightly from Intellijel 1U modules. For that reason the module graphics for Intellijel must be padded top and bottom or the modules will look cropped.
modulargrid
See also https://www.modulargrid.net/e/forum/posts/index/3391
