![ModularGrid Rack](https://cdn.modulargrid.net/img/racks/modulargrid_645500.jpg)
OK...you'll notice I made the cab bigger but many modules got smaller; as a result, it's a tighter, better-implemented version. Case is a Pittsburgh EP-270 (3 x 90 hp), inexpensive for the size but with beefy power specs: 4A on +12, 3 on -12, and 2 on 5 to power 1679mA on the +12 rail, 861mA on -12, and 25mA on the 5V. This way, the power supply gets to loaf along on a light load, reducing heat and component stress and improving stability.
5 VCOs now: I shrank the Verbos Complex VCO in favor of a Sputnik, which is not only smaller, it has a little bit more going on functionally. Then there's a TZFM VCO, and two regular Doepfers. Ring mod got added, then a 4-in summing mixer before a Tiptop wavefolder with a suboctave generator. Triple VCA mixer at the end along with a passive mult (the one at the VCO end is active, plus tandemmed with a dual switchable-direction slew limiter).
Modulation row: noise/random/S+H, then a pair of EMW LFOs. Maths (of course) next, then the next two modules are an Intellijel Quadra (four AR/ASR loopable envelopes) with its expander/CV control. Erica dual ADSR next, then two filters: a Doepfer A-106-1 and a Limaflo Motomouth.
Now, these are weird filters, to be sure. The Doepfer is a dirtier take on a Korg MS-20 Sallen-Key pair, but it has this weird feature: an insert point in its resonance feedback circuit. This means that you can drop stuff into that path and alter how the filter pair deals with its resonance signal in loads of ways...for example, the filter next to it, which is a very weird vocal formant-morphing thing. So, with that sort of path, you can have the regular LP/HP combo, but everything feeding back to cause resonance is getting colored up by vocal vowel formants. That's just one example of this sort of A-106-1-type mayhem. There's others, to be sure.
Bottom row: your Metropolis is there, but I did something to the Quantimator: it mutated into a two-channel Doepfer quantizer and a two-channel shift register, with a lot of potential variation that the single-channel Quantimator could never have pulled off. Now, you can actually assign one voicing to the first quantizer/shift register, and put another on the second two...or put the VCO pitches on one side and the filter cutoffs on the other, or...well, you get the idea. Same device, but twice as nice! Two more VCAs, primarily for CV use but they can also switch to exponential for audio, then a TriATT, which can be used as a set of attenuverters, a 3-in mixer, or three channels of CV offset...or a couple of those at the same time.
Four-in stereo mixer, this goes to the Morphagene, which allows you to loop/granulate/warp/mangle the entire synth's output in stereo, with the output module (with transformer isolation and a ganged stereo level pot) right there for output to line-level.
So, yeah...it's quite a bit of your idea, just refined, put into a bigger case, and tightened up with a straightforward signal flow pattern. Fairly cost-effective for the size, too...modules came in at $5106, case is $599 street. Now that's a respectable starter Eurorack, with an eye for unconventional sound and plenty of potential. Whatcha think?
