That new feature does more harm than good. I rolled all changes back.
-- modulargrid
You need a "thumbs up" or "thanks" button for forum posts so we don't have to reply to say "thanks"!
-- modulargrid
In Rack view under Switch and in the command center the names are now sorted "naturally" instead by string.
was:
1. Rack 1
11. Rack 11
2. Rack 2
now:
1. Rack 1
2. Rack 2
11. Rack 11
The markdown editor in the forums has now a toolbar where you can set text bold, italic, set bullit lists and insert the markdown code for links and images in case you don't know where to find the square brackets [] on your keyboard.
The News from the Lab section has an updated design
When you select a Manufacturer via the Manufacturer Drop Box in the Module Finder an info block with related info will be shown
Since Twitter won't allow free access to their API anymore we have removed Twitter from the ModularGrid Modular News section :(
Modulargrid now supports the super affordable AE Modular format!
Fixed a small bug that prevented new manufacturers from posting news.
In the process accidently deployed a new feature were users can thumbs up forum posts.
A simple Thumbs Up function that lets you leave a thumbs up on a forum post.
Second click on the Thumbs Up button removes the Thumbs Up.
Narcists can thumbs up their own posts.
In the planner there are two new buttons that appear on hover to push one or more modules to the adjacent side.
This can also be used with shortcuts n and m.
The older shortcuts , and . to push only single modules still exist.
The button to flip modules is removed because I think that was not used enough and took too much space. The function is still there with shortcut f for flip.
Push entire row of Modules
-- modulargrid
in my opinion it would be better to close the remaining gaps with each push one by one with each click
your soulution removes all gaps at once
thx anyway
-- modulargrid
dudes, the rotate/flip fuction was essential.
the way it worked before was way better.
please put it back / make Rotate available.
-- modulargriddudes, the rotate/flip fuction was essential.
-- RunnyKine
I agree. Would prefer flip.
Also, it is more difficult to move 2-4hp modules around now. There is a very tiny space that you must grab.
Thanks for everything you do!
also, btw, regarding the Flip feature - the Keyboard Shortcut you mentioned doesn't apply to people who use their phones to access MG, which is what I do 99% of the time (and surely many others do as well).
please put it back like it was. thanks.
In the user preferences under https://www.modulargrid.net/e/users/view you find a new fieldset called Planner Menu Preferences. Here you can check which entries you like to see in the planner action menu. Options are Push Buttons and/or Flip Button.
You can select both but the space will be very narrow on slim modules.
I have seen terrible webserver performance lately. I found out the reason was a search engine spider that crawled all Similar Racks pages. That is a page with very hefty SQL queries and for that reason a CPU/memory hog.
Quick fix:
Similar Racks now is only accesible for users that are logged in. Thinking about changing it in a Unicorn only function...
There is something wrong with the Screenshot thing!
-- Hikove
maybe, but what??
it'll really help if you describe what's going wrong - not just "Houston, we have a problem!"
-- Hikove
Screenshot thing makes screenshots again, thanks for reporting!
When you select a Manufacturer via the Manufacturer Drop Box in the Module Finder an info box with related info will be shown. That's old news. But if you don't need that info now you can hide that box with a click and it will stay hidden even after logout.
Besides module images I never wanted to host user uploaded images on the server because of the potential trouble with backups and malware.
But users pointed out that in case of the marketplace it is very helpful to send images via the messenger to not disclose their private data/ email adresses early. So that is possible now. You can send one image per message.
The images are hosted on a Google Cloud Server. Because that service charges money for hosting and traffic the new feature is an Unicorn Only feature.
Since I have no idea how expensive it is in the long run the image upload is an experimental feature, so save any important images localy, because the data might vanish again.
The Richtext editor is now available in the marketplace section.
Ever noticed the small image icon in the top right of the Richtext editor? That used to insert the markdown syntax for images. Now it lets you upload images and they will be displayed inline in the forum texts and marketplace offers.
An experimental feature that might be reverted.
Let's start with image No 1, a must have for every modular user: my potted plant.
Modules now can be ordered by positive rail in the search.
The entire site and the screenshot server moved to a new faster server. It's now cloud everything 16 core/64GB RAM with SSDs and whatnot. All the server software (Linux, PHP, SQL, ...) was updated, we have a web firewall, the screenshot software was rebuild from ground. Still some hiccups here and there but overall it went well.
We lost the www in front of www.modulargrid.net. The site is now just modulargrid.net (as if anyone would ever notice).
A new unpopular feature that nobody asked for: I've limited the number of automatic watchers you can set for offers on the marketplace.
On the module detail pages is that button Notify me if someone offers this module for sale. Standard users can sign up for 5 module notifications, while Unicorn users can set up to 2500 watchers.
The reason for this is that the mail server has been blocked several times due to excessive traffic, causing important features such as user messaging and optin registration to stop working.
Yes, it is now possible to hide the cat to appear to tell you to Clean up the mess!
Find it in your user settings.
The Used Price History history on the marketplace includes now the median price. The median price ignores the very low and very high offers and could therefore represent the more realistic price. Unicorn feature.
Unicorn users can export/import their racks as json data
Bug Fix: the Median Price function now calculates the median and not some fantasy values.
There is a new filter option Show Blank Panels in the module search form that let's you hide modules with the function tag Blank Panel assigned.
This is a workaround until we have refactored the entire Alt Panel functionality.
The Top 25 Popular Modules statistic on the homepage counts how many modules have been added to racks since the beginning of ModularGrid time in 2013. This gives you an approximate indication of how popular a module is.
But times and modules change, so in addition to the all-time favourites list, there is now a filter that limits the list to modules released in the current and last year.
So if you want to know which is the 🔥 hottest 🔥 module of 2024, you can find out now.
There is also a Top 100, find the filter at the bottom.
The new manufacturer index page lists all manufacturers per modular universe and answers the question of how many there are. Find it in the main nav.
https://modulargrid.net/e/vendors
Unicorn users can export the power consumption data sheets of their Racks as CSV to do whatever they want to do in Open Office/Excel.
You now can choose from a module detailpage to which of your racks a module should be added.
Power Consumption as CSV
Rack Chooser on the Detailpage
-- modulargrid
Rackchooser feature is clutch! Thank you!!
The choices which region offers should be displayed in the marketplace are now saved.
You should already have seen this if you are reading this post: we have new cookie consent settings. I also looked over the site, evaluated and removed cookies that were not necessary.
This is a plattform which uses external content like YouTube videos, Soundcloud, Bandcamp and I think that should stay this way. The new settings reflect that.
tldr; we have regained a bit more privacy
In addition to the created field modules now also have a published field. Manufacturers could always upload a module as private and change later to public. Now, when they change the module to public the published field is written and the module will show up on first position in the module browser when sorted by new. This only works once, it's not possible to bump modules.
The change will make published modules more visible. Before the change depending on the upload date they were burried in the module list.
fixed narrow line heights in headlines in module description
If you check/uncheck Show Blank Panels in the modules search form the change is saved in the database. Next time you log in this will be used as default value so you don't have to hide them every time.
Visits counter of racks resettet. See here
The Keep me logged in! function now uses a more modern, security-focused token workflow. In practice, this means that even if you checked that box on a computer that isn’t yours, you can now log out from any other device and instantly revoke that persistent login.
It isn’t compatible with the old system, so many people will have to log in manually over the next few days.
We have updated the user view. Everything should look nicer, load faster and we have some new functions like a stats panel and the possibillity to add your YouTube, Instagram and Soundcloud channels! How else would the world discover your next fire modular ambient track?
-- modulargrid
That's awesome, the new design really looks nicer now. Thank you very much for the update!
One small bit of feedback: the module thumbnails now being cropped into squares makes it harder to recognize modules at a glance. It would look more natural if they kept a constant height and variable width, similar to how they appear in real life.
Thanks!
Ruben
The site will be offline on Thursday, 19 March, from around 09:00 CET for approximately two hours, so plan your racks accordingly.
Mar 19th - Facelift for the entire site
With a slow or unreliable internet connection, it could be hard to tell whether a large rack had fully loaded. Now, each module has its own loading indicator. The position where a module will appear is also shown with a dashed placeholder outline. Works also with pedals.
If you never see any of these indicators - congratulations, you have a great internet connection.
We have Swap Rows in the Planner Edit Menu for some time. Now we also have Move Rows which makes a similar thing but without the swapping :)
This is a Unicorn feature.
You can now exclude terms from the free-text search using the “-” operator.
To find filters that are not Wasp, enter:
filter -wasp
In this specific case, I’m not sure why anyone would want to do that, though.
Greatest new feature in a long while :-))
Though: While 'wasp -doepfer' works as expected, 'buchla -tape' still lists modules by Tokyo Tape Music Center.
What am I missing here?
Have a nice week end.
-- wiggler55550
The exclusion currently only works on the description text not the manufacturer name or title
It’s a bit sad, but we now have a user block list. If you receive a message you don’t like and don’t want to get any more from that user, you can block them. They won’t be able to send you new messages until you unblock them.
All blocked users are listed on your user page.
... also we have a new Lightbox on Module View that opens if you click on the module image.
You can now rotate Eurorack modules 90° so they will fit in a 1U row! This works only for modules up to 6 HP.
You can still drag them around and also Optimize Rack Space continues to work.
Use the Rotate Button in the planner action menu. If you don't see that button check, that it is activated in your user preferences or use keyboard shortcut f for flip.
