The main modular. Planning took forever. Lots to test. So far, yikes it sounds big.
I tried to keep the most typical connections to be close enough for the Little Yellow Wires.
I'm using a Deftaudio midi hub down next to the Misha, but MG doesn't have their listing.
Note use of the two Doepfer A-180-9 Multicores. The cool thing is that you can use two ribbon cables and connect them from the back.
That gets 14 lines from the note clocks on the left over to the voice modules on the other side, without draping a dozen wires across the box.
The 'ethernet' connectors still work for connecting other synths.
I have to go back and study the Misha and Nerdseq manuals a bunch more.
Hopefully someday I can tame that Mob of Emus. They are always ornery.
halbroome
Herding Emus is definitely wild -- half the fun is doing it blind!
