Hi you modular pros,
I have an idea in my mind, but I'm not sure how to build it into reality. But maybe you could help me. I drafted my current setup (only the relevant modules) in the picture below.
I want to play an audio signal into my modular system, this should be recorded at channel 1 of the DLD for let's say 16 bars, then I want the DLD to play these 16 bars (modulated through the Clouds) and at the same time record the incoming audio signal into channel 2. After another 16 bars the channels should be switched, so that channel 1 is recording again and channel 2 is on playback (modulated through the Erbe-Verb).
What do I need to do/change/add to make this using the current setup?
Any hint is appreciated!
Best,
TheMM
