New module yay! Been working on this in the past 5 years. Made of ~900 components, including 44 VCA, 146 opamp & 36 switch channels spread on two 6 layer PCBs, this is going to be one of the most complex eurorack modules...
It is a fully analogue modular compressor built to go far beyond traditional dynamics control. Complexor combines low-noise, high-quality compression with advanced sidechain processing, multiple topologies, and dual-band / dynamic EQ modes with audio feedback and 1V/O CV inputs that invite experimentation.
It can be clean and polite.
It can be aggressive and unstable.
It can be played and modulated.
With feedback-capable routing and frequency-dependent dynamics, complexor behaves less like a utility and more like an instrument inside your system. It delivers the depth and flexibility often associated with digital compressors, but without aliasing or digital artifacts, thanks to its entirely analogue signal path.
Why did I make it in the first place? I started working on complexor because I kept running into the same wall.
Digital compressors had the flexibility I wanted.
Analogue compressors had the sound I liked.
None of them really let me play the dynamics.
So I started sketching a compressor where the sidechain wasn’t just a detector, but a place you could patch, filter, split, recombine, and even feed back into itself. Somewhere along the way it stopped being “a compressor design” and started behaving like a small system of its own.
Complexor is the result of that process. It’s fully analogue, not because of nostalgia, but because nonlinear analogue behaviour still does things I don’t hear in digital. Especially when pushed into feedback, saturation, and time-varying control.
I’m building this as a single-person operation under modmonk dot eu
If you’re looking for a clean utility compressor, this might be excessive. But it covers that too.
If you’re looking for a dynamics processor that can be gentle, violent, unstable, and musical, often in the same patch, then this is probably for you...
🙏 Full description: https://www.modmonk.eu/shop/complexor-pre-order-2026-2
🙏 ModMonk Website: https://www.modmonk.eu/
🙏 Demo video:
🙏 Modulargrid: https://modulargrid.net/e/other-unknown-modmonk-complexor
🙏 Modwiggler: https://www.modwiggler.com/forum/viewtopic.php?t=298622
🙏 Facebook page: https://www.facebook.com/profile.php?id=61576785873862
🙏 Youtube channel: @ModMonk_eu" target="_blank">https://www.youtube.com/@ModMonk_eu
