rextable
To anyone hoping to use MIDI to control this module, be warned:
Yes - Dimension mk3 responds polyphonically to midi through its midi jack, but that's where the midi implimentation ends. MIDI CC assignment is not implemented meaning that, apart from the three assignable CV inputs on the front, there's no way to control this module's many many parameters via physical knobs or sliders. The result is that, come what may, you'll be fishing around in the menu. This is acceptable while pottering around in the studio but, in the heat of live performance, it becomes very tedious very quickly. What a spectacular missed opportunity! But for this glaring oversight, Dimension Mk3 is excellent. I sincerely hope Ziqal address this shortcoming in a future firmware update. If they do, Dimension will truly be the best one-stop-shop solution for polyphonic voices in Eurorack. But until then...
I've attempted to contact the manufacturer to ask if they intend to further develop Dimension's midi implementation in the future but have not had a response. So one has to assume the answer to that question is "probably not."
Sad face :-(
Does anyone know how i get in contact with Ziqal, ive tried emailing them several time with no luck?
