We created Mudras as an alternitive to the two step process of
1.) Compose CV Sequence
2.) Play CV Sequence
Instead Mudras allows anyone to experience the exhilaration of live improvisation by combining the two parts into one. With traditional instruments this can take years of practicing technique and learning scales, but Mudras allows anyone to do this immediatly by translating hand motion into quantized CV sequences.
Check out the following demonstration video to see what we mean, would you be able to create the same melody using any other sequencer?
Featuresā
ā
Record and loop up to 64 Steps
- 7 Quantized V/Oct Music Scales
- Linear CV mode for modulations
- All steps are input live in real time single steps or entire sequences.
- Recorded steps are output live in real time as you input the sequence
Analog Style Clock Input
- Sequence steps forward once for each rising edge trigger/gate on the clock input
- Lock directly with any trigger/gate sequence, including any swing or completely random sequences
- Responds to sub microsecond trigger widths
Novel LIDAR Sensor based user interface
- 700 mm range/ 1 mm resolution
- CV Output defined by movement of hand through the air as the sequence play
- Input up to 60 notes per second
- Sequence play back well into the audio range
- Can be used as a real time musical interface by holding the record button.
Available only directly from IC Alchemy at https://icalchemy.com
