this is my Ambient rack
mainly for Dark Ambient
what would you get next,what do i need
use a sq-1 and beatstep pro as sequencers
also have this small effects skiff
Envelopes.
I really like the Tiptop Buchla 281t because it has 4 loopable envelopes with CV control over attack and decay plus a quadrature mode that kind of makes them all loop and interrelate in weird ways. You might like it in an ambient case as a sort of freeform brain/hub for modulation and clock - I tend to use it both as 4 individual envelopes and also as a weird freeform sequencer of sorts. It's a big module, but it looks like you already have some spots where you've got some cramped modules.
But whether or not you take my specific suggestion, I would just say look at envelopes that you can play around with by hand in contrast to the Zadar, which is awesome but not quite as hands-on, for some variety. I wouldn't put any more small little modules in there unless you find one that really speaks to you, and I'd probably even start looking at blank panels to put in between some of those things at the top.
All of this is sort of beside the point, though: what do you yourself feel is missing? Do you like how it feels so far? Is there anything you don't use as much as expected? Do you like the Forbidden Planet filter? There's always another filter to try out.
Thanks will check out the tiptop buchla
The right module next for you is the module you want. I don't understand why guys are asking other people how to design their rack or which module to buy.
if it were me, I'd get a morphagene first. Then, maybe an endless processor. Clouds or Beads. IDK if you have a bitbox already but I didn't like it. It was just a big bright screen in the middle of my rack. It didn't feel like eurorack modular to me. Powerful, but so is my computer.
i already got all the modules shown in the posted racks
-- GunnarWaage
I get it. I like to have others' thoughts when I feel like I need to make a decision. Each of us can always learn something. I think asking others is just part of the learning process. There's always going to be sombody else out there with more smarts and experience (at least compared to me :)~ And, I'm going to want to hear others' experiences when I'm undecided about dropping the kind of cash that a Eurorack system can soak up!
-- Broken-Form
So, like others have already asked, what's not blowing your mind right now? Are there things that you use all the time? Do you have any modules that you like but have a hard time actually using? What makes you think that you need another module, other than a desire to fill up empty space? Do you just want some blind recommendations, or are there things/sounds/effects that you want to learn how to create?
I think that's what I take away from Gunnar's comment, above. If you want useful recommendations, it helps to have some idea of what you are looking for. IOW, if you don't know where you're going, you're probably not going to get there. And I say 'probably' just because even a blind squirrel gets a nut once in a while.
So, to my point, here's my suggestion... Since you want to do dark ambient, you may not be interested in adding some percussion but, since I'm not yet sure what you're looking for, that's what I would miss in your rack. Personally, I can't imagine having a rack without it. You may not want a 4/4 kick or snare hits cutting through your dark ambient atmosphere but it would add creative possibilities for adding punctuation and playing around with tempos and rhythms.
At the same time, there's nothing wrong with not having any percussion modules in your rack. Be bold! Do your own thing! Best of luck with your journey!
actually one thing ive been thinking i would like do is connect my Alesis Q25 midi keyboard to my system for more "Playability"but i need a midi to cv module for that right?but what module would work im abit baffled with this?
If you just want to plug a keyboard into your modular, buying a plain Arturia Keystep will be cheaper than any MIDI to CV converter in Eurorack.
A Keystep Pro would be even better and would probably streamline your sequencing/producing here by giving you both the keyboard and access to multiple sequencer tracks, but that is a bit of a price jump from the Keystep or even the mighty Beatstep Pro that you have (plus the Keystep Pro lacks all the cool knobs).
The regular Keystep is your best bet here for just adding a single keyboard, though. It's cheap, has its own CV connections, does sequencing/arpeggios well, and can even be used as a MIDI to CV converter if you want to control pitch and gate of a module from, say, your computer. MIDI to CV is expensive to do in the rack and none of the cheapest options give you much mire power than a Keystep
Honestly, you seem pretty set. If anything I'd maybe add a utility vca and more another modulation/envelope source. The real question is what do you need, what are you missing when you patch?
If you're set on using your Alesis keyboard look into the Befaco Midi Thing or the Noise Engineering Univer Iter. Otherwise you can go with a keyboard with CV outputs or you probably have enough space in your rack for a TSNM or another Pressure Point or similar controller.
You could also consolidate down and move your effects skiff into the main rack if the sizes here are representative.
Don't let unnecessary GAS get you. you have your bases covered, practice and master your modules and eventually you should naturally figure out what to weed out if it's not working for you or where to expand if you're missing some functionality.
also interested in a filter that would compliment the forbidden planet,but maybe be a bit more "playable"bringing something else to the table
I'm fond of this filter:
https://www.modulargrid.net/e/eowave-tempete-magnetique
and one that is smaller:
https://www.modulargrid.net/e/supercritical-synthesizers-neutron-flux
For "dark ambient" the Nautilus as a delay processor would be a good addition:
https://www.modulargrid.net/e/qu-bit-electronix-nautilus
Now that you are "down the rabbit hole," you'll constantly switch modules and such in search of what is best for you.
Have fun 8'). Think of it all as a haiku poem, getting as much out of a small framework as you can. Going big prematurely
costs a lot and can be wasteful. Concentrate on one module type at a time, and winnow things down.
I think you have all what you need. anything more will be luxury and G.A.S.
but if you have the money
Filters:
I like bastl Ikarie - 8 hp stereo filter with drive
or Winterbloom Neptune
Mimeophon, Nautilus or Sealegs could be an idea depending on your taste.
Morphagene or Nebulae
for great sounding percussion, SSF Ultra Perc is the shiiiit in my opinion
for dark stuff - SGR 20 from Knobtechnology
its my favorite new toy. Its a analog vco, noise maschine , Industrial drum voice, drone maschine
The vco is a variation of the buchla triangle and it has some buchlataste in it.
I think the SGR gives a new special flavour and im a big fan of it.
Sry if this goes to far, but I just want to share my euphoric
get a SGR 20 😁
Greetings
Chris
