No user found with username lumot
A Euclidian LFO. Uses the Euclidian functions (search for the math if you’re inclined) to add beats between intervals, and in this case has 4 outputs all handling things a little differently. Most similar euclidians just output trigger pulses to run sequencers, this one has modifiable waveforms, which you can use with a seq or much more CV targets.
Simple to use in basic manipulation but has many more waves and other functions that will allow you to go way deep if you want.
Mostly surface mount pre-installed, so a simple build.
Build
