FYI you can fit deeper modules in any skiff or case by using standoffs. You can get packs of hundreds of them in different lengths from places like Amazon for about $15. You screw the standoff into the slot and then screw the module in via a thread in the standoff. I like the brass ones as the nylon ones can break too easily.
  That would free you up to choose any 2hp (brand) module. Maybe the mixer would be a good match as you don’t seem to have one.
  -- main_tenant
hhmmm - not convinced by this: it potentially exposes the boards/components to the wild - ie short circuiting them by accidentally coming into contact with stray patch cables etc - which may or may not damage the module and/or power supply...
in other words do this at your own risk...
& just because someone has done this and not short circuited anything so far, doesn't mean it's not going to happen - it just means it hasn't happened to them, yet!
and it looks crap...
