How do I sync the cv and gate on the Varigate 4+ so that when pitch is outputted, a corresponding gate is fired? Right now it is all out of sync so the envelope is not opening properly.
Thanks
Thanks
	Set the varigate switch in the middle position (2/2) now you have channels 1 and 3 for cv and channels 2 and 4 for gate.
Simply program the step that you want with the fader all on the right (100% prob of firing a gate)
You can advance the sequence with a clock or a trigger pattern to advance when you want instead of a constant clock.
Hope it helps
