hey guys,
I'm thinking of buying an ES-8 because it looks like a really useful module for interfacing with Ableton & MaxMSP. I have a Motu Ultralite mk3 and was wondering if anyone has any experience with using the two at the same time.
It says on the website you can use the ES-8 with another interface via ADAT, but I've never used ADAT and also have no idea what that would look like (for example, I can only select one interface/driver in Ableton or MaxMSP, so how does it recognize the second interface...?)
best,
the ES-8's ADAT ports are additional channels of the ES-8. If you just want more eurorack jacks from an existing interface with ADAT ports you probably want something more like https://boredbrainmusic.com/product/optx/ and/or the ES-3/6
thanks for the reply! does that mean I use my MOTU and the optx via ADAT can be installed to show up as an additional 8i/8o channels ?
I'm having trouble finding info on that specific model, but yes, if it supports ADAT then yes that's pretty much it - you'd just hook up the optical cable and use the extra channels. Do note that ADAT and S/PDIF use the same physical connector but are not actually compatible protocols, so be sure which you've got on the MOTU!
I'm pretty sure you can use the es8 as a standalone ADAT expander - don't use the usb and connect the ADAT I/O to the ADAT I?O of your Motu... the extra channels will show up as part of the Motu in your DAW
check the manual - it's easily accessible on the ES site!
you know what i totally forgot it did this because i always have the usb plugged in to mine! But honestly, for use as an ADAT converter from an existing interface i would still probably go for the optx for the full 8x8 channel set...
ES-8 works great as an ADAT expander, I have one permanently connected to my audio interface and only use it in USB mode rarely. The Optx does have a channel advantage, but if sending CV into your DAW the ES-8 has DC coupled inputs as well as outputs.
Iโ€™m not sure if the Motu Ultralite mk3 does have ADAT though, so def worth double checking that. If confirmed that it does not, (and youโ€™re using a Mac), the ES-8 will have the advantage of being able to be set up as an aggregate audio interface (this doesnโ€™t work so well on Windows).
