It seems like my modular gets covered in dust easily, so I've two questions you guys surely can help with.
Due to the dust a couple of modules have developed scratchy knobs, usually fully moving the knobs back and forth solves the problem, but lately the scratch seems to persist in one of the knobs and I'm not sure how to fix it. It seems like I need to clean it with "air spray", do I need to fully remove the front panel of the module before blowing the air or is it ok to just remove the plastic knob? Is there any other/better way to get rid of the scratchy knobs?
And then, how do you keep dust away from your modular? some cases have a cover like a suitcase, which I guess helps a lot keeping the modular clean, but other cases don't. Do you cover your modular in some way? or how do you keep your modular dust free? So far I've been cleaning mine with a brush, but some of the dust always seems to find it's way into the knobs and sliders.
I have a lid on mine but covering I with anything should help.
Befaco make a brush which I recommend
Not to mention Cat hair, it clings to rubbery knobs!!
For cleaning — DeoxIT
https://caig.com/deoxit-d-series/
-- cmb_
"Rejuvenator and protector". I may use that one on myself instead
-- cmb_
I use and endorse DeoxIT, frankly! My can of D5 is currently sitting next to the Digisound 80, in fact. The stuff might seem like it's just basic "contact cleaner", but it goes a lot further than that...it adds lubrication to a pot that doesn't gum up after time, for one thing. And then, yep, it's got some anti-tarnish ingredients to help keep contacts from getting crapped up again.
It was so ubiquitous in Nashville back in the day that, if you ran into a crackly pot or intermittent switch with the resulting noise, everyone would be lunging for the DeoxIT can, unspoken rule-style.
I don't know if it's a EU/US thing, but if I google DeoxIT I get tons of WD-40 results in front. Is it the same product? It's certainly cheaper.
Also, I know it's not the manliest of sights, but I use one of these artificial feather dusters for all my gear and so far I've had no dust-related problems. And it's so light you can dust your VCOs without getting them out of tune!
Do it, go full on Freddy Mercury.... Embrace that duster, if it works, it works :) I use a clean paintbrush but cat hair is still tricky.
Btw, Don't use WD40
-- Mazz
Oh, HELL no! WD-40 is basically spray-on cutting oil, like 3-In-1 Oil or Liquid Wrench! Get that into a pot, and you're going to probably need to replace that pot soon after that. The only similarities to DeoxIT there is that both come in a spray-can...and that's IT.
Now, as for cleaning panels...I use a rather small shop-vac + a couple of tight-space brush attachments. Even with that vacuum, it still takes a brush to knock the dust up so the vacuum can deal with it. Note, however, that a vacuum will not deal with bloodstains...although, that will probably be of more concern to the 1st-gen Industrial and Power Electronics crowd.
I currently use DeoxIT Faderlube for scratchy pots with great results but years ago I used WD 40 very often. I know it's a formula for water displacement but it also lubricates a bit and I could revive some pots and buttons with it.
It might not be the ideal solution but I don't have any broken pots due to WD 40, I don't think it is corrosive like Kontakt 60.
DeoxIT International Distribution:
https://caig.com/distribution-2020/?cn-s=&cn-cat=8
You can search by country from there.
All the best.
I couldn't find DeoxIT in my local store either and looking at the distribution page it doesn't seem to be available in my country. However, searching on Amazon the DeoxIT D100S-2 seems to be available and I guess it would do the work too, so probably ordering it even though is much more expensive than the wd-40.
You do realise that WD-40 is named as such as its 'Water Dispersal version 40' its made for dispersing water on your car with old-fashioned Points on the ignition system. Don't put that shit anywhere near a synth in my opinion!
