I'm hoping to use the MIDI clock (coming from TASCAM model 12 mixer/recorder) as my Master Clock. I'm trying to control all my gear (Minilogue XD, SQ1, Boomerang Looper) along with my eurorack so everything is on the same time. Plus when I go back to record additional tracks (on Tascam model 12) I want to know that I'm running from the same reliable clock from my mixer/recorder so there's no timing issues. I got a MIDI box (1 in: 4 out) and it works great to multiply the MIDI signal from the Tascam Model 12, to all the (non eurorack) gear but.... What is the simplest way to get a good midi clock from my mixer to eurorack. Is there a simple adapter or do I need to spend a couple hundred on a midi to cv converter module. I would probably be going into a (4ms quad clock distributor module) as my main-starting eurorack clock divider/distributer.
Any comments or wisdom appreciated!
