I was watching Mylar's Suggested Systems 4 (link below) and he mentioned that Emilie has accused folks of being lazy with Rings and not "exciting" it, so I sat down to mess around with that (since Rings is relatively new in my rack). This patch developed over about 10 days and I just kept adding more modulation all over everything. Probably way too much, but it was a good learning experience and a lot of fun. I thought it was a good dark ambient follow-up to How Do You Make It Let Go.
Here's the live performance recording (take 11?) with a little EQ and compression added:
Here's the patch:
https://www.modulargrid.net/e/patches/view/78672
And here are some notes:
Master Clock from Pamela’s New Workout
A slow sequence from Rene’s X channel is driving OSC A on the Piston Honda
The sequence is in C Dorian
Piston Honda’s Y and Z wavetable banks are being slowly modulated by Ochd
That’s going into Bionic Lester’s Filter A.
BL’s Filter A Freq is being modulated by Ochd
That’s going to the In of Rings
Rene’s X channel gate is feeding Rings’ Strum input
Rings’ Brightness and Damping are being modulated by Ochd
Rings’ Position is being modulated by RND Step
Rings is going into Mimeophon and out
That same sequence is linked on the Piston Honda to OSC B
Those wavetables are also modulated by Ochd
That’s going into Bionic Lester Filter B, who’s Freq is modulated by a Quadrax LFO
BL is going to a delay
Rene Y channel is sending a slow sequence to Plaits
The clock for that sequence is set to 75% random skip chance on PNW
Plaits’ Timbre and morph are modulated by Ochd
Plaits is going into Ripples
Ripples Freq is modulated by RND Step
Ripples is going to Quad VCA with Quadrax for envelope and then to a delay
Disting EX providing kick and hit hat
PNW driving the triggers for Disting
Hi hat is a Euclidean pattern
Hi hat is going through Polaris
Polaris freq is modulated by a Quadrax LFO
Polaris Q is modulated by RND Step being triggered by a S&H LFO from PNW
Bass and hi hat are going to X-Pan
Hi Hat pan is modulated by a Quadrax LFO
Everything is going through a Big Sky and recorded in Studio One 5
Mylar's awesome tutorial on Generative Systems:
