User left
Well...it certainly seems expensive...and probably pointlessly so.
All of your Moogs are already in powered cabs. And the Moog 3-tier accessory will work just fine at assembling those into a single unit. So it makes no sense whatsoever to decase the Moogs and reload them into Arturia RackBrute cabs. It might SEEM "convenient", but the real truth here is that you're contemplating spending a lot of money with little return.
A far smarter move...and certainly CHEAPER...would be to keep the Moogs in their cabs, use the 3-tier bracket there, then add something like a Tiptop Mantis at the very base of the Moog rig so that you can have your additional modules there. Even though a Mantis costs $335 street, when you add up the cost of the additional Arturia cases, the cost of the unused Moog cabs, and the extra Arturia P/Ss, this definitely exceeds the cost of the Mantis by a sizable chunk.
One other point, also...what the Moogs need isn't so much additional expensive modules, but more akin to UNsexy stuff...attenuators, logic, a clock manipulation setup to really make their sequencers go nuts, additional utilities of that sort. Sure, some FX and the MScales are definitely called for here. But if you do this RIGHT, with a PROPER additional cab, you'll then have plenty of cheap room in which to build up a more comprehensive "sidecar" for the Moogs than you have currently. Plus, you could just as easily add a fourth "voice" in the additional cab.
