Jam in Cm.
Main sequence comes from Varigate 8+ and MiniMod oscillator 2. Then to Morgasmatron which is in parallel mode. OUT A (LP2 and then BP mode) goes to Left input and OUT B (BP mode) goes to the right input of Magneto for the dotted 8th delay effect.
Notice that Voltage Block sends a random 1 volt through Intellijel Quad VCA (which receives a random gate at the CV input from Varigate 8+) to 333. 333 acts as Precision Adder as both quantized pitch CV from Varigate and VB’s 1volt meet there before they go to MiniMod oscillator 2. The result is a random 1 octave pitch change for the notes of Varigate’s sequence.
See patch here:
https://www.modulargrid.net/e/patches/view/65270
Lead voice comes from the Make Noise DPO. Oscillator A is in LFO mode and its EXPO input is modulated from Batumi which is in expert mode (Matthias Puech firmware) for the trembling effect. Same for oscillator B (distorted voice).
Marbles sends random pitches in Cm to DPO (lead voice). Also sends random pitches to BIA which is responsible for some weird noises. Both BIA and DPO goes to Clouds (delay+reverb)
Bassline comes from Varigate 8+ and MiniMod oscillator 1 (triangle) which goes directly to 531 output mixer.
I should keep Blck_Noir’s Kick MORE in that reverse reverb mode!! After I heard the recording I noticed how good it was..
See patch on ModularGrid for more details:
https://www.modulargrid.net/e/patches/view/65267
Gear:
AJH Synth MiniMod Vintage Transistor Core VCO
Intellijel Morgasmatron
Mutable instruments Marbles
Expert Sleepers FH-2
Make Noise DPO
Intellijel Triatt
Xaoc Devices Poti
Xaoc Devices Batumi
Frap Tools 321
Xaoc Devices Belgrad
Strymon Magneto
Frap Tools 333
Intellijel Quadra
Noise Engineering Basimilus Iteritas Alter
Intellijel Quad VCA
Mutable instruments Clouds
Endorphin.es BLCK_Noir
Malekko Heavy Industry Varigate 8+
Malekko Heavy Industry Voltage Block
Roland SYSTEM-500 531
