Sorry for the Confusion guys
  I'm pretty new at this.
  Lets start again
  The way I m using this set up is to obtain some sort of ritmic randomnes
  In my sequences and record it Midi in the MPC. (The results are pretty good)
  My main question is about the doepfer A 192-2 CV to Midi module
  Since it has 2 independent channels
  I m still not able to figure out how to use the second channel so I can run 2 random sequences from 2 different midi channels
  Right now I have it's midi in going in to the out of my MPC 2000xl
  Which controls other Synths:
  Roland D110
  Akai S2800
  Volca Bass
  Volca fm
  Then the A192 goes to the blue lantern Quantizer for pitch (thru an LFO and or Sample &hold) and Temps Utile for ritmic randomness
  -- Carlobrunetti78
Your description doesn't make a lot of sense.  The A192 converts CV and gate to MIDI.  So the path you're describing is out from the A912 to the Quantizer and Temps Utile.
The A-192-2 only works on POSITIVE voltages.  So if there's an LFO in the mix, you'll have to offset it so that there aren't any negative voltages flowing into the A-192-2.  It will just ignore negative voltages.
By default the first set of CV inputs goes to MIDI channel 1.  The second set goes to MIDI channel 2.  There are 16 possible MIDI channels available over a DIN MIDI cable.  I would test these inputs.  If you can connect the MIDI out to a computer MIDI input and run any software that's capable of displaying the raw MIDI data coming in, you could confirm that the unit is functioning properly.
