When clicking on the module's picture from the following page, an older version of the module's image is used.
https://www.modulargrid.net/e/other-unknown-ishizeno-one
Also, what should be the process for adding a new module maker? ISHIZENO sounds a lot better than "other-unknown".
Thanks in advance for your help!
modulargrid
That is probably a cache issue on your browser. Looks good here.
Added Ishizeno as manufacturer. Welcome to ModularGrid!
-- ishizeno
Thank you! Everything is working fine now.
It now mentions the A-131 Exponential VCA on the right hand side. Is that expected?
modulargrid
-- ishizeno
This is an automated API query to http://www.eurorackdb.com/ which "guesses" best results for your modules name.
If you are listed there, too this will vanish.
